migbox
I broke a screw..
Thu Jun 01, 2017 1:18 pm
While replacing a SIM module, I twisted a screw too hard and broke it.
Half screw is in, so I cannot simply replace it.
Is there any place in Italy where I can bring the phone to be serviced?
And perhaps also have the Android 7 update applied by skilled people?
thanks in advance
Re: I broke a screw..
Sat Jun 03, 2017 9:04 am
In the phone box, there are also several screws included and tools.
Do you still keep the box? You can check and find them.
migbox
Wed Jun 07, 2017 9:44 am
Yes, but half screw is inside the phone.. I need a tech who can extract the broken screw..
Thu Jun 08, 2017 2:37 pm
As far as I know there is no special Blackview repair store in Italy.
You could try to use a pointed pliers or going to a local mobile repair store.
Tim.strange
Sat Jun 17, 2017 8:01 am
You can purchase replacement back covers on aliexpress.
Sounds extreme but I think its the only option as I've not seen any screw extractors small enough.
And do it before you get the phone wet!
