I've found a issue with my new phone.
I love it, and it is a great experience however when on 4g(LTE) I cannot receive calls. However if I set the preferred network in the settings to 3g, it will receive calls well but because Blackview misrepresented the supported 3g bands for the phone I have no internet. (A few of you may have noticed this, and there are threads about this were people have proven it, and the admin stops replying)
There are a few other people with the same issue posting in this forum being ignored, please don't ignore them and this and work with us.
The issue is with the OS, or possibly the antenna. The ones with the issue have networks that don't support VoLTE (Voice over LTE) and are simply pure data LTE bands, and the network when a call is coming in on 3g(Or even 2g, depending on the carrier) it pings the account and see if it is using LTE, and switches the phone down to 3g to complete the call, then switched back to 4g(LTE) after the call is completed.
The issue I've found is that the BV5000 selects 4G(LTE), 3G, or 2G. Which doesn't leave those who need to use multiple bands with a usable device.
My wife has a Sony Xperia Z3, and the options are as such. 2G, 3G, 2G+3G, and 2G+3G+4G(LTE). Being able to use all the bands allows the phone to switch back and forth as required.
If it is an antenna limitation, just let us know and that will be it. However if this can be patched, I would be happy to work with you towards a solution.
If you are having this issue chime in and lets get this noticed.
