bhaddock66048
A8 MAX ROM update problem.
Thu Apr 13, 2017 2:57 pm
I downloaded the new ROM and installed the Mega software ( you have to if you want the ROM) reboot reset to factory settings and cleared coach. Went to SD card and the ROM update will not show so I can install, can you please tell me how to update your ROM if it will not show up???? 8A MAX_BLACKVIEW_20161220.rar. Currently running 8A MAX_BLACKVIEW_20161018.
Please help.
Re: A8 MAX ROM update problem.
Fri Apr 14, 2017 5:44 am
You can be finding flash manual in the below link, it also can be useful on A8 Max.
viewtopic.php?f=29&t=116290
bhaddock66048
Tue Apr 18, 2017 4:34 pm
Thank you! :D
