EtienneBIDEAU
Availability of USB-C charger for Blackview BV7000
Wed Apr 05, 2017 1:06 pm
I have recently purchased the Blackview BV7000 and am very satisfied with it.
Unfortunately, I have lost the charging cables that were included in the package. I have bought and tried other USB-C type chargers and connectors, but they do not fit in the charging port of the BV7000 because of the waterproof design of said port, wich makes it deeper and harder to attain. All the chargers that I have found and tried are blocked by the plastic part, larger (too large to fit in the Blackview's port), that comes after the actual connector.
As a consequence, need to know about the possibility of being supplied with an original Blackview USB-C charger.
Thank you for your answer, have a nice day !
Etienne BIDEAU
Re: Availability of USB-C charger for Blackview BV7000
Thu Apr 06, 2017 6:46 am
Hi friend, thanks for getting in touch. Please go to the online shop where you bought your phone to get support, the shop will contact us directly.
Davros84
Thu Apr 06, 2017 9:23 am
I would also like to buy some. Please make them available or direct us to somewhere we can buy them.
Fri Apr 07, 2017 2:26 am
Hi friends, please find the link for BV7000 Pro cable.
https://pt.aliexpress.com/wholesale?cat ... 7000+cable
Charru33
Fri Apr 07, 2017 3:03 am
I've tried the aliexpress link but there's only cables for the BV6000, check it, please
peluso
Fri Apr 07, 2017 9:32 am
Write him before ordering, cables BV6000 and BV7000 are different and there may be a mistake.
I too am looking for the USB-C original cable Blackview for BV7000 but I can not find it, sold separately. My phone seller does not have it yet.
Pablo0208
Mon Apr 10, 2017 7:14 am
none of the listed eBay & Ali express sellers have BV7000Pro chargers & cables (usb C) (only BV6000 models which are NOT COMPATIBLE (usb micro) ..Admin need to let us know if Blackview will do something about tit asap & gives us proper / official suppliers to get chargers & cables
adamepc
Mon Apr 10, 2017 10:15 am
Likewise for headphones is there an adaptor perhaps so we can use our own headphones as the ones in the box are pretty poor which is to be expected, I've ended up using a knife on the headphones jack for some apple ones but this isn't ideal as did the same with a usb cable but it didn't last long unfortunately
Semi technical UK user
SIRO
Mon Apr 10, 2017 8:23 pm
dear BW team,
I am waiting for delivery of a 7000 Pro, and I am a bit surprised with this issue of the unavailability of those "special" cables. Where we stand with that? Would you provide us with any updates on after-market availability?
I need to have 3-4 of them (car, office, home, etc.). Thanks for your understanding,
Siro
