w14a
firmware needed
Tue Apr 04, 2017 7:53 pm
Dear friends,
The usb port is damaged, only charging is working. In order to reflash the phone we need any firmware version zip file that should be flashed from SD card. Could you please provide us with proper update.zip file? Currently the 0.3 version is in use. Thanks.
Re: firmware needed
Tue Apr 11, 2017 6:47 am
Hello, I will check with our technical person about this.
