BlackView-User
Sim 2 not working
Fri Feb 17, 2017 8:10 am
I live in the UK. I have purchased the P2 direct from Hong Kong.
Sim 1 slot works OK.
The TF slot works OK.
But I cannot get the Sim 2 slot to work at all.
Sim 2 always says SLOT EMPTY no matter which sim I put in.
Is this a fault?
Thanks,
Re: Sim 2 not working
Mon Feb 20, 2017 7:23 am
The TF slot can also be inserted the sim card. You can only install nano card.
BlackView-User
Mon Feb 20, 2017 7:56 am
To make this work, I had to bend the second SIM card into a contact lens shape, only then would it would register.
So yes, this is a design fault either of the board or the dual SIM tray.
BlackView-User
Tue Feb 21, 2017 3:59 pm
To get this working I had to bend the SIM into a contact lens shape.
