louf
root device - get code
Mon Feb 13, 2017 10:54 am
into parameters/devellop option/root device
how to get the unlock code for root device ?
thanks
Re: root device - get code
Tue Feb 21, 2017 1:30 am
You can find the code on our forum.
perchera
Sat Mar 04, 2017 11:01 am
As you see admin is not very helpful.
"You can find it in the forum" he says. It would help if he points you to the right place.
We need a new admin!
Published by BV on Feb 14
viewtopic.php?f=171&t=109228
Activation Code: 252258439
schiltronics
Wed Apr 19, 2017 4:56 pm
How do I put the code in there
schiltronics
Wed Apr 19, 2017 5:00 pm
tmsjaeger1
Sun Jul 02, 2017 1:35 pm
the link doesnt work, can you post it again please?
Mon Jul 03, 2017 3:05 am
Root code: 252258439
To do this you go into Settings>About Phone> Tap build number until it tells you that you're a developer> go back to Settings> Developer Options> Root code.
Pattuck
Mon Aug 07, 2017 6:17 am
Thanks work for me ;)
