BV5000 Latest ROM Download Web Link
Fri Dec 04, 2015 10:01 am
Welcome to download the latest ROM for BV5000:
https://mega.nz/#F!Kkl1iR4K
The Entry Password for the following ROM:
!_QK8gGqIgCbKOTG5M5tQgQ
Any question or help , pls leave an message here, we will reply you as soon as possible.
Thanks for your support !
BV5000 5_副本.jpg (46.39 KiB) Viewed 26320 times
sdml
Re: BV5000 Latest ROM Download Web Link
Fri Dec 04, 2015 5:31 pm
We still can't set different ringtones to sim cards.
nyfd_it
Fri Dec 04, 2015 6:01 pm
Instruction for installing?
ccggg
Fri Dec 04, 2015 6:44 pm
I download latest rom to microsd.
And I try to install by manual method.
But, update manager can not find a *.rar file.
How to install rom?
nyfd_it
Fri Dec 04, 2015 8:57 pm
Updated with the indications in the post "Blackview BV5000 Flash Manual"
Thank you.
Mat13127
Sat Dec 05, 2015 11:56 am
Hello friend, this rom is rooted?notification led doesn t work, is it normal?thanks
vecinu95
Sat Dec 05, 2015 1:41 pm
Thank you for the update! Is there any changelog?
boroda
Sat Dec 05, 2015 3:24 pm
Please tell me.
Is there a compass and with what program it works?
Is there a 5GHz band WiFi?
The serial number on different phones of the same are 0123456789ABCDEF is this normal ?
vecinu95
Mon Dec 07, 2015 8:57 pm
dave136
Wed Dec 09, 2015 8:14 am
Hello, I upgrade ROM by manual. But after restart missing IMEI, pls how fix it. Phone work, wifi work, but write IMEI incorect. Rom ver. isw 1.5. Thx for help.
