Xhris
3G logo but no data
Wed Mar 30, 2016 7:03 am
i have a BV2000s and i have 3G logo (in the top bar) but no data. All applications says "no connection aviable". I tried an other sim, same probleme. I tried the 2nd sim slot, same problem. I also check my APN all is ok.
The connection works fine in wifi.
Thank's a lot.
Re: 3G logo but no data
Fri Apr 01, 2016 6:15 am
So it is the first time that your smartphone can not connect to 3G data networks ?
Best regards,
Admin
