I have a problem with my new BV5000.
It seems that there is no push functionality.
When using apps like whatsapp or the facebook messenger, the messages only receives when the app is opened.
If the app is closed i'm not able to receive the message.
When I open the app again, then the message will be received.
I have the latest Build. BV5000_C1_Blackview_V1.5_20151110
I've tried to do a factory reset, but it won't fix my problem. I've also tried every settings for batterymanagement and data usage.
Has anybody an idea?
thx
