Miran Rexhepi
How to update ROM , all steps and zip's for it in the description
Wed Apr 27, 2016 7:41 pm
Hello admin, i want to update my blackview bv5000 , i got the rom but i don't know how to do it, send me the zip links and instructions.
Cause i'm having troubles with wifi.
I looked at the other instructions , but they are like piecies of puzzles.
Thank you , for your support !
Re: How to update ROM , all steps and zip's for it in the description
Thu Apr 28, 2016 9:06 am
in fact we have publish a flash manual on forum long before.
here is a link for the flash manual :
viewtopic.php?f=96&t=1027
And this is just a flash manual , so the ROM zip inside is not the latest one , so may not the one you want .
and the follwoing link is for latest ROM ZIP :
viewtopic.php?f=96&t=16680
Hope it can help you
Best regards,
Admin
steirx
Mon May 09, 2016 12:19 pm
I have just posted this on the other thread and I might be stating the obvious but I had struggled to figure this out myself as well. So, for what it's worth - here is how I updated my phone with the manually downloaded ROM. In my case, there was no need to root the phone, etc. [BTW the ROM was Android 5.1 not Marshmallow 6].
1) Simply download the ROM zip file an transfer to your SD card (internal or external)
2) Go to Settings
3) Click on About phone
4) Click on wireless update
5) Click on three vertical dots in the right hand top corner
6) Select Local updates
7) select SD card / folder / ZIP file that holds the ROM update that you have downloaded (manually)
And follow the steps to upgrade / update your ROM.
Hope this works for you!?
