prakasam
[TRACKED] Bluetooth connectivity issue for second time or second device
Mon Jan 28, 2019 9:48 am
Hi Team, I am facing an issue with Bluetooth connectivity
Scenario: I have connected Bluetooth morning 9 am, afternoon I have disconnected to charge my Bluetooth when I try to reconnect back it failed to connect it,
after restart my mobile it was connecting to the same device automatically .. so please solve the issue ASAP it was a bit hard to restart the device every time .
prakasam
Re: Bluetooth connectivity issue for second time or second device
Tue Jan 29, 2019 4:39 pm
Hi, did you try to simply deactivate and reactivate the bluetooth on your phone?
prakasam
Mon Apr 22, 2019 1:31 am
Yes I tried. .but no use . When I turn off the Bluetooth and wait for minit and turn on the device no use ..so after I restarting my phone ..it was automatically connecting ..
I noticed one more issue ..
Key board delay for typing ..wen I open what's apps or browser .key board opens .. when I type the text it was not entering into application ..it was showing as suggested words when select the words also it was not entered the to app (Browser , what's app )
When re open the application it was working good ..
prakasam
Mon Apr 22, 2019 9:49 pm
Please perform a factory reset and try again. After doing a factory reset don't load a previous backup and don't install any other app. Just try your Bluetooth and report back if anything changes.
prakasam
Tue May 14, 2019 6:18 am
I have done a factory reset, the problem was still the same ..
my mobile mike was creating echo voice distabance for all phone calls .. when I use Bluetooth headset only voice was clear .. so that why Bluetooth was important for me.
prakasam
Tue May 14, 2019 8:01 am
Can you please try another bluetooth headset? Sometimes the issue is more related to the headset than then phone.
prakasam
Mon May 20, 2019 1:48 pm
I tried that too ..I have few head sets
- lg
- bluedio
- zenlot
But all are same ..
I have connected device ..It was connected  ..But still voice coming to hand phone ...
It have mike problem ...And then I restart the device working fine ...
Scenario
- connected device .. able to make calls using Bluetooth
- when getting some distance Bluetooth disconnected.
- And when come to near the phone it was connected automatically.
- But the voice not transferring to Bluetooth device
- when I restarted the mobile it was again connecting and I am getting the voice from Bluetooth (note: I have tried restarting Bluetooth headset but no use ..Device connecting but the voice coming from handphone only )
I hope this explanation is good enough to understand the device problem
prakasam
Tue May 21, 2019 1:08 pm
Ok, can anybody else confirm such issue?
lalloral
Sun Jun 02, 2019 4:20 pm
I have a similar problem with my Polar H7 heart rate monitor, it connects correctly but after a while (the duration is random), it disconnects.
The pulsometro works correctly in another phone with a Rom custom android Pie (Resurrection remix).
Factory reset does not solve the problem.
Mon Jun 03, 2019 1:13 pm
OK, such issue has been tracked. Tech team will investigate.
