Paul.david.carr
SIM card installation
Tue Nov 06, 2018 4:28 am
The 9500 Pro does not recognize my SIM card. There are no instructions on how to proceed, but I think I match the picture in the booklet. Is there a video available?
Re: SIM card installation
Wed Nov 07, 2018 5:03 pm
Put your SIM into the slot. Then perform a factory reset and report back.
Roni
Wed Nov 07, 2018 9:36 pm
Use slot 1 (left side) if only installing one Sim card.
Paul.david.carr
Fri Nov 09, 2018 6:05 pm
It is ok, but I can't get AT&T 4G. I do not think this is a problem with the SIM however. They do not have an answer. It may have to do with no support for Band 12.
Sat Nov 10, 2018 6:22 am
It looks like incorrect APN settings. You'll have to contact your phone carrirer to solve that.
BV9500 has a great coverage with AT&T, as you can see here:
https://www.kimovil.com/en/frequency-ch ... iew-bv9500
