MRUK
Rattling inside phone
Tue Dec 18, 2018 1:53 am
Just noticed my phone is rattling inside, cannot remember dropping it anytime but all of a sudden its rattling. (not SIM tray)
Everything still works, its just the annoying rattling.
Do you have an idea what it can be that's causing it?
jaja
Re: Rattling inside phone
Tue Dec 18, 2018 10:56 pm
alarm maybe ? or application notification ?
note : I hope, I understand fine the problem because i use translator for "rattling inside" !
regards
jaja
MRUK
Wed Dec 19, 2018 2:30 am
The ratteling coming from inside the phone as if something broken off.
Wed Dec 19, 2018 7:58 am
Unfortunately, to know it you'll have to open it. If your phone works without problems and you can't open it, don't open it.
jaja
Wed Dec 19, 2018 11:00 pm
hi,
ok, thank you, I understand better. unfortunately, I do not have a solution. sorry.
regards
jaja
