R123
Bug on bv 10000 pro
Mon Oct 15, 2018 10:27 pm
Hi
I bought a new phone and there is a small bug, when the phone is turned on, and asks for code the keyboard never shows up, for me to dial up the code.... The solution is to go to emergency call and then turn back to original menu, after that keyboard will show up and allow us to put the code to start the phone
Re: Bug on bv 10000 pro
Tue Oct 16, 2018 11:06 am
Never heard about that on this device. Please perform a factory reset and check again just after that.
R123
Tue Oct 16, 2018 12:37 pm
Hi administrator, did that and it still the same, forgot to mention that the phone came with android 8.1.
Thank you
Fri Oct 19, 2018 12:54 am
Where did you buy your phone?
R123
Mon Oct 22, 2018 5:15 am
I bought it new on ebay, and it came from UK seller
Drambuss
Mon Oct 22, 2018 4:18 pm
Hello, l had the same problem. It is if you have the SIM security lock turned on.
Mon Oct 22, 2018 11:08 pm
Just disable it and the bug will disappear ;) thanks for the feedback!
R123
Sun Oct 28, 2018 8:22 pm
Ok thanks guys :)
R123
Fri Nov 16, 2018 11:51 am
Hi admin
Just want to say that latest update removed this bug... Thank you Blackview
Fri Nov 16, 2018 7:42 pm
R123 wrote:
Hi admin
