Gibbo
BV9000 Won't make or receive calls
Tue Apr 03, 2018 10:24 pm
Hi, I have purchased 2 x BV9000 phone and both are experiencing the same problem.
Neither phone will make or receive phone calls.
Both phones are connected to a 4G Network, they can receive cellular data and can send and receive MMS & SMS.
Can you please advise what problem would be preventing the phones making or receiving voice calls?
Thanks, Gibbo
Re: BV9000 Won't make or receive calls
Wed Apr 04, 2018 3:37 am
hello,
please tell us your firmware version and we will report it to the tech team.
btw, how did it happen? any updates?
Gibbo
Wed Apr 04, 2018 5:32 am
I have found the problem.
Australia's main mobile network is Telstra and their 3G network is 94% covered with B5 850MHz which isn't supported by the BV9000.
Do not buy BV9000 for use in Australia !
Sat Apr 14, 2018 12:05 pm
Thanks for your feedback!
Cen265
Wed Jul 25, 2018 11:03 am
I am having the same problem, it has nothing to do with the network, A friend has an identical phone and uses the same network and has no problems. Mine will not make or receive calls.
Mon Jul 30, 2018 12:19 am
In your specific case, your device is faulty and needs to be replaced under warranty, You'll have to contact your seller for that.
