amalek
Touchscreen issues
Fri Dec 01, 2017 11:02 am
Hello... the new ROM (A7Pro_blackview_20171031) has some touchscreen issues.
Its hard to Pulldown the Android Quick settings Menu... i need 3-5 tries to pull it down...
and sometimes the Home, Back and Menu button have an own life... they make inputs without any hands on the screen...
can you help me?
Greets from Germany
amalek
Re: Touchscreen issues
Fri Jan 05, 2018 2:35 pm
am i the only one with this problem?
cuchu
Fri Feb 02, 2018 9:29 pm
Did not flash the new rom after reading this. Don't have problems with the old rom.
Hope you're getting help soon.
And I'm looking forward to a stable new rom as well ;-)
amalek
Mon Mar 12, 2018 9:06 am
After some months and changing the Digitizer two times... i don´t know if it is a problem with the new ROM!
I had this problems with the digitizer so i bought a new digitizer on Aliexpress...
The new digitizer works perfect... but i broke it after a week :?
So I bought a new digitizer from the same Shop on Aliexpress.
But the new digtizer had the same issues like the original. :cry:
My question... There are two versions of the touch screen on the market???
The first digitizer i bought (works perfekt) had a protective film on the inside.
And the last not working digitizer did not have this protective Film!
two different digitizer? did i need another driver for this?
sorry for my bad english :oops:
Users browsing this forum: No registered users and 10 guests
