kullvilla1
problems with the load
Thu Nov 15, 2018 7:54 am
The phone does not charge while it is on. only charge when I turn off the terminal and being off and without having released the cable while I turn it off to load but only when it turns off, only charge when it is off, I tested with different type C cables since I also have a bv8000 pro.
Re: problems with the load
Thu Nov 15, 2018 9:02 pm
I suggest you to perform a factory reset and report back if something changes.
kullvilla1
Re: problemas con la carga
Fri Nov 16, 2018 7:57 pm
OK, the factory reset is done from Android or from the boot Start menu of the system, which is better?
Fri Nov 16, 2018 8:06 pm
from the boot start menu it's better, in my opinion
kullvilla1
Sun Nov 18, 2018 12:24 pm
The factory reset is already done from the boot menu. it still does not charge the phone being turned on ... it does not join
Sun Nov 18, 2018 8:14 pm
I suggest you to contact your seller and have your phone replaced under warranty, as it is definitely faulty,
kullvilla1
Wed Nov 21, 2018 2:54 pm
Okay, I'm saying goodbye to Blackview forever.
sad
MTom18
Thu Nov 22, 2018 9:06 am
sad
Understandable. The Manufacturer has only the interest to buy. no ex-post support.
Although I like my own s8 but I'm already looking for the offspring.
