redfield
No cable USB type-c is recognized by the Blackview S8 for data transfert
Sat Apr 07, 2018 9:28 am
I have a very annoying issue with my my blackview S8, i wanted to buy a new cable Type C (premium quality and certified for qualcomm quickcharge 3.0 and data transfer). I've bought 4 differents cables and absolutely none of them work for data transfer. In the other hand, charging with those cables work like a charm.
I've tried those cables on two PC, on many USB ports 3.0 and 2.0 with no luck
The only cable working for both charging and data is the original one that came in the BV S8 package.
I'm really worried because i've bought 4 cables for nothing. It won't happen again.
Please give me an explanation.
Regards
Christophe Mathieu.
Mail perso : mathieu-christ@orange.fr
skype : play3net@hotmail.com
ICQ: 67364387
Re: No cable USB type-c is recognized by the Blackview S8 for data transfert
Thu Apr 19, 2018 6:55 pm
1) Can you try your cables with the same PC but different phone?
2) You can always use the OTG adapter wich came out of the box ;)
redfield
Sun May 06, 2018 7:27 pm
Hi bv admin,
Will try the cables on a different phone that uses a usb-c connector, and will update my post on the forum to let you know the results.
But i'm still wondering why the cables i've tried and that are certified for both charging and transfering did not work
once again, the usb-c officially bundled with the phone works, so i will ask you again, is the official cable using a propietary connector ?
below the kind of cable i've used.
Cable USB-C data transfer
thanks for the answer
Regards.
Regards
Christophe Mathieu.
ICQ: 67364387
Tue May 15, 2018 12:55 pm
redfield wrote:
Hi bv admin,
Regards.
The connector is standard as far as i know.
