bv800 pro useless after update
astrobod427
Postby astrobod427 » Mon Sep 04, 2017 3:03 pm
Yesterday, third of september 2017, I updated my phone throu the built-in updater and since then it is useless.
The phone boots correctly but when startup is complete the screen gets black after a few seconds and there is no way to use it anymore.
It is very annoying...
I need help
Re: bv800 pro useless after update
Postby blackview_admin » Tue Sep 05, 2017 11:15 am
Hello! You need to flash latest stock in firmware upgrade mode via PC. Link on firmware: viewtopic.php?f=192&t=213272
Return to “Service and tech”
