nesterov32
Firmware P2 lite
Thu Jun 01, 2017 1:52 pm
Hey. When will a new, flawless firmware be released that fixes all the bugs described here? As a bug application-phone, errors with microphones (conversational and noise reduction).
People buy your phones, so please kindly correct the software mistakes that are made during the use of the phone. All the same, phones are not cheap, and I would like something to react faster and more fruitfully.
Re: Firmware P2 lite
Wed Jun 14, 2017 7:31 am
Hello, about the microphone problem, please contact the online reseller to get repaired or replacement.
Jyothiraj
Fri Jun 16, 2017 7:01 am
Mr. Admin this is not a good reply try to solve this issue, otherwise your brand value will decrees we like the phone , give a updates with solution
jyothiraj India imei :35**72080306428,80306410
Wed Jun 21, 2017 6:08 am
"Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select ""reboot system now"""
If still can not fix it, please let us know.
jyothiraj vb
Sat Jun 24, 2017 11:38 am
hai Admin , its me jyothiraj , problem not solved with this boot.same problem continuing ,please give a updation for OS with rectifies software.its problem with OS.
