thd100tv
NEW ROM
Mon Oct 09, 2017 9:11 pm
For when new update of p2 lite we have been months with failures and Google now does not work is left the System stopped when a Whatsapp arrives and when many arrive it goes off. T Please send update 7.1 Above bluetooth audio is delayed and the roman is not certified or signed by fav
Re: NEW ROM
Tue Oct 17, 2017 3:26 pm
update to the latest Firmware and perform a factory reset in recovery after that.
thd100tv
Re: NEW ROM
Tue Oct 17, 2017 3:49 pm
nothing follows the same does not respond send a solution or a patch
thd100tv
Re: NEW ROM
Tue Oct 17, 2017 3:59 pm
someone has the blackberry android 6.0 firmware link to test it until it solves android 7.0 and its mortale stops
thd100tv
Re: NEW ROM
Tue Oct 17, 2017 4:12 pm
someone has the blackview android 6.0 firmware link to test it until it solves android 7.0 and its mortale stops
thd100tv
Re: NEW ROM
Re: NEW ROM
Wed Oct 18, 2017 1:44 pm
Your posts are not easy to understand. Please take some time to write then instead of posting several time a day.
Here are all firmware files I can give you: viewtopic.php?f=182&t=323101&p=545900#p545900
There is also a flashing tutorial. Make a flash to 20170622 and update OTA to 20170804.
