Marco-66
Android 7 Version 20170706 - Problems to solve
Sun Aug 06, 2017 8:49 am
I think it is a good idea to list here all problems that we have .... so the admin does not go mad and a solution will be find more quickly, I hope ..
I have already written some topics but I will put all issues I have here :
    1) There is "Blackview jingle" that is played two times when the phone starts, can be disabled ? (I already got a reply here viewtopic.php?f=175&t=176383, no solution)
    2) Sometimes the phone reboot itself (about 2 times in a week). It seems a problem of this ROM version. (it seems be solved ..)
    3) A little but significant percentage of the video (about 5%) I have done until now is not "focused".
    4) The Serial Number is 0123456789ABCDEF (all hexadecimal digits ..) --> this issue is present from the Android 6 version.
    5) The Outlook Client App (version 2.1.249) about 4/5 times in day stop running. It seems a problem of this ROM version.
    6) I cannot hear well who is talking with me, already changed the UL gain via engineer mode.
    7) Volume: how to set differently for notification and for the telephone ringer.
    8) Bluetooth vulnerability
If you want to add your problems here please :
    Check that the problem is not already listed.
    Check that you are running the version Android 7 20170706
    Use few words to describe your issue.
    It points out whether the problem is related to the current version or whether it has always been present.
    Significant information in order to help who will solve the issue.
I will update the list with yours issues and update.
HTH
PS : I don't know if the "BV7000_PRO_Blackview_20170717" version listed here --> Official ROM download links viewtopic.php?f=176&t=191529 is the same ROM that I'm now running (Android 7 20170706) installed via Ota.
EDIT 06 Aug 2017 added point 6)
EDIT 14 Aug 2017 added point 7)
EDIT 24 Sep 2017 added point 8)
The point #2 seems to be "magically" resolved .. Now it is enough time that it is not rebooting itself automatically
diable131277
Re: Android 7 Version 20170706 - Problems to solve
Tue Aug 15, 2017 10:50 am
Hello I have avheter since can a bv7000pro and I have wifi that does not work, it deconecte impestively forced to put the version BV7000_PRO_Blackview_201700523 these the wavelength that the wifi works the other version the wifi beug .que puije do thank
bonjour j'ai avheter depuis peut un bv7000pro et j'ai le wifi qui ne marche pas ,il deconecte impestivement obligé de mettre la version BV7000_PRO_Blackview_201700523 ces la ceule que le wifi marche les autre version le wifi beug .que puije faire merci
Marco-66
Sun Sep 24, 2017 4:07 pm
We need a patch for this ..... ASAP.
https://www.theverge.com/2017/9/12/1629 ... -blueborne
https://www.androidcentral.com/lets-tal ... nerability
Thu Sep 28, 2017 3:32 pm
Marco-66 wrote:
Thank you for your great help!
I already reported the blueborne issue to our technicians and (as always) we will provide the android security update as soon as possible.
Marco-66
Fri Oct 13, 2017 11:23 am
Any news ?
Marco-66
Fri Oct 13, 2017 11:49 am
About issue #5 , The Outlook Client App, I have many times in a day this error, can be solved ?
(APP already re-installed, I DO NOT WANT to do a factory reset ...)
Of course I have the same APP installed in other Android devices without any problem.
karera
Sun Oct 15, 2017 8:32 pm
To solve Marco-66's first problem, you should have a rooted phone and a root explorer. Rename these files by adding .bak extension at the end: /system/media/bootaudio.mp3 (for blackview jingle) and /system/media/audio/ui/camera_click.ogg (optional: only when you set the smart key to capture a picture but you can disable this on camera app) and /system/media/audio/ui/camera_focus.ogg (optional: for camera focus sound).
I hope this helps.
Marco-66
Sun Oct 15, 2017 9:45 pm
I hope this helps.
Thanks Karera, I do not want to root my phone, I want a solution from Blackview, I hope it will be in the next update ....
