pfavayi
Unroot & replace patched boot.img with original
Thu Jul 13, 2017 6:14 pm
I flashed marshmalow (android v6.0 ) on my blackview P2 , rooted it with the root method provided in development options (actually superSU is the root binary), installed flashify and gave it root , then used flashify to install the twrp 3.0.3 img file.
Everything worked well so far
I then unrooted the phone successfully through the development options and the superSU app.
But when I tried to flash magisk through twrp , the flash aborted because the boot.img was patched.
I don't understand how the boot.img can still be patched when I uninstalled superSU per-instruction.
How can I unroot superSU and make sure it replaces the patched binaries with the original boot images ?
