nickyboy1979
Android pay
Mon Oct 17, 2016 10:09 pm
Android pay is not working same problems as posted in the bv6000 forum. Phone is not rooted have checked with root checker.
Re: Android pay
Sat Oct 22, 2016 2:09 am
if your phone is BV6000, then try to install the software of 20161011 version to fix the problem.
Sukram
Re: Android pay
Thu Oct 27, 2016 1:47 pm
What is the sollution for 6000?
chrisb
Re: Android pay
Tue Nov 08, 2016 6:57 am
Where can i find 2061011?
jul1592
Re: Android pay
Tue Nov 08, 2016 6:03 pm
I have a problem with installation the new firmware.
I can't find the zip file on the phone.
I go to :
* about the phone
* update
* local updates
And then the only choice I have is "SD Card". When I touch "SD Card", the following message appear :"No zip file in this directory". But it is...
Note : internal memory is merged with sd card.
Have you a solution ?
Re: Android pay
Fri Nov 11, 2016 6:46 am
Go to seek a help from related topic on BV6000 Board.
viewtopic.php?f=142&t=79088
Re: Android pay
Fri Nov 11, 2016 6:51 am
I go to :
* about the phone
* update
* local updates
which rom you are talking about.
Some roms on our official forum can be just installed via flash tools via pc, but not for a local update.
