dale
Re: BV6000 Firmware Flash Manual
Sun Apr 09, 2017 7:55 pm
I have the same issue.
The phone got bricked.
And you won't be able to fix is yourself.
migbox
Wed May 10, 2017 10:43 am
Good day all.
One question for BV Admin.
I tried to detect if any upgrade was available OTA, but I got the message that the phone is up to date.
The question is: when it will be available OTA an update for those one who do not want to brick the phone following a procedure?
In alternative, is there an assistance in Italy where I can bring my phone and have the work done?
btw, I have Win 7-64, so in case I would need a procedure dedicated to this OS
bvbw
Wed Jun 07, 2017 12:15 pm
Is it possible to flash manualy BV6000 with W10 32 bits ?
Thu Jun 08, 2017 3:02 pm
migbox wrote:
Good day all.
If OTA update don't work you could try local file update (relatively safe) or flashing over a computer (for experts).
bvbw
Thu Jun 08, 2017 9:16 pm
I repeat my question : Please, is it possible to flash manualy BV6000 with W10 32 bits ?
Thanks
Dongermon
Thu Jun 08, 2017 11:35 pm
Thanks
yes it is, you need to install the drivers and sp flash tool heres a link to my tutorial on win 7, theres a link by another user thats for windows 10
viewtopic.php?f=172&t=130585
bvbw
Fri Jun 09, 2017 6:15 am
Thank you Dongermon ...
Dongermon
Fri Jun 09, 2017 2:21 pm
Glad I could help
Wed Jul 05, 2017 12:38 pm
Here is more simple flash tutorial: viewtopic.php?f=144&t=147109
sidsood
Sat Aug 12, 2017 1:56 pm
Hello friends,
I have made a "Flashing guide" to update your Blackview BV6000's ROM to Nougat 7.0.
Please follow the link below and update ROM. You could also find a "TWRP installation + Rooting Guide" for your Blackview BV6000.
http://dreamworks75.blogspot.in/2017/08 ... v6000.html
Happy Flashing !!!
