costantino6
Re: Release notes 20170708
Mon Aug 28, 2017 7:36 pm
This is my third message and I hope it will be finally published. My WiFi keep switching off all the times when I am listening to music with my Bluetooth speaker jbl flip3. My internet provider is BT. I am in London. Can you please do anything about? It is really annoying.... Hope not to write this message anymore.
bvbw
Wed Aug 30, 2017 9:48 am
Bluescorpie wrote:
Is there will any update continuos periodicly ? Or Is this the end of software update?
I really want to know also if it's end of BV6000 updates ?
blackview_admin is not active on BV6000 forum since long time now ... smell bad :evil:
costantino6
Fri Sep 01, 2017 11:25 am
I am happy to tell that with a factory reset I finally sorted out my problems and I would like to thank blackview for the last update that works very well so far.
Bluescorpie
Wed Sep 06, 2017 1:02 pm
This happened on my bv6000, wifi bugs
Aimless
Wed Sep 06, 2017 9:32 pm
Go in to the router settings and disable either 2.4ghz or 5ghz. The phone keeps switching between the two disabling the WiFi in the process, or rollback to android 6
costantino6
Fri Sep 08, 2017 3:38 pm
Thanks everyone.....
However it would be great if blackview will continue to keep update our bv6000.
Thanks
Fri Sep 08, 2017 4:13 pm
Thanks for your help!
Netsplitz
Re: Release notes 20171011
Thu Oct 26, 2017 10:05 am
updated with 20171011 changes
Thu Oct 26, 2017 1:24 pm
Thank you Netsplitz for keep this up to date. I post every change-note I receive with the update link but often I don't know all changes. I made your thread "Sticky" now because it is very helpful for other users.
McSNox
Fri Oct 27, 2017 11:52 am
Hey. Update 20171011 only under Flashing? Is there no local update or OTA? is there any reason to install it on top of 20170708, if the mouse is 89?
Blackview BV6000 V01_20170708
