wikan
where can buy battery BV6000
Mon Nov 21, 2016 5:04 pm
where I can buy battery for BV6000, I was in Indonesia
my BV6000 battery is broken
Re: where can buy battery BV6000
Tue Nov 22, 2016 9:13 am
You can try to buy from aliexpress online stores.
The Master
Sun Jun 18, 2017 8:08 pm
Hi and tnx for support
It seems that BV6000 battery is out of stock both on AliExpress and Mobiles Parts
My BV6000 suffer of anomalous battery draining and I need to replace battery
Parcheval
Mon Jun 19, 2017 7:29 am
It's probably not the battery. Everything was OK with mine until I suddenly experienced huge battery draining, max 12-14h before it was needed to charge it again... Tried to re-install the same firmware with local update without any success, so performed a back up of my data (MyBackup or Titatium apps for example), re-flashed it to the same firmware (20170517 in that case) + Factory Reset afterwards, and voilà, last recharge last Thursday night and still have 34% of battery left!
97gérard216
Mon Jun 19, 2017 8:07 am
Parcheval wrote:
"re-flashed it to the same firmware (20170517 in that case) + Factory Reset afterwards, and voilà, last recharge last Thursday night and still have 34% of battery left!"
Can you explain the method for making a "Reset Factory". Thank you
Mon Jun 19, 2017 1:29 pm
Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select "reboot system now"
97gérard216
Mon Jun 19, 2017 2:02 pm
Thank you admin
