silvietta
local update: how to?
Mon Jul 09, 2018 10:45 am
Hello all,
first of all, please excuse me if I'm re-asking something that someone else has already asked in other posts that I haven't read so carefully as I'd be supposed to ...
Second, please forgive me for being ... how can I say? ... illiterate? in mobile phones and computers field, but I'm "just" a chief cabin assistant, definitely I'm not an electronic engineer!
So, let's start with my question (my three questions, being precise):
1) my BV6000 last update is 20170708 and didn't solve reboot-while-calling (due to contact ear and phone) problem; there will be another update in next future (another update that my phone will benefit, I mean, since none of last 6 updates did arrive to my phone!)
2) and, if I want to update by myself to 20180330 (locally, ie downloading update in sd card and configuring update manager to get the update itself from there), it's safe? I mean: is riskless? No risk to have my phone "kaputt" and to be in needint of buying another one?
3) if I update to 20180330 as I've said above, will the reboot problem be resolved?
Thanks for answering and have a nice day you all,
Silvia
mobosenshi
Re: local update: how to?
Tue Jul 10, 2018 3:43 am
You should flash instead of doing a local update. The latest ROMs require flashing via PC. Personally, local updates don't work on my BV6000.
silvietta
Tue Jul 10, 2018 12:12 pm
  flash instead of doing a local update .... I don't know how but mostly I don't trust, I mean I know I won't be able and I fear to destroy my phone: as I stated, I'm not an electronic engineer, just (?) a chief cabin assistant.
But ... it only happens to you (local updates not working, I mean) or is "normal" that local updates shouldn't work?
Best,
Sil
mobosenshi
Wed Jul 11, 2018 9:24 pm
Local updates appear to upgrade but they actually don't. I had to flash my BV6000 in order to get the latest ROM.
Users browsing this forum: No registered users and 16 guests
