MikeCP
BV6000s will not turn on
Sat Apr 21, 2018 3:58 pm
My BV6000s has suddenly stopped working. It shut down saying there was no charge in the battery when a few seconds earlier it was showing 35%. How can I make it restart? A long press on the on/off button does nothing. I briefly had a picture of a battery on the screen when plugged into charger but nothing since. Help
Re: BV6000s will not turn on
Tue Apr 24, 2018 8:57 am
Unfortunately it looks like an hardware fault... i suggest you to contact your seller for a replacement under warranty.
