lenny
BV6000 slow after upgrade to 7 android
Fri Aug 25, 2017 2:54 pm
After flashing the phone from android 6 (pre 20160822) to 7 (20170708), the phone became stupidly slow, opening facebook or viber takes about 20-30 seconds, other apps got slow as well. Can this be solved by downgrading to earlier ROM, or should I just go back to 6.0?
4G does not work either, never did actualy, I was hoping that an update will solve this matter, but it did not
Re: BV6000 slow after upgrade to 7 android
Fri Sep 15, 2017 5:02 pm
I will report this. You may try out flashing other versions. Please also try a wipe/factory reset after flashing.
