tolomelli.luca
Android 7 [20170708]: where is Glove Mode?
Thu Jul 20, 2017 8:14 am
Re: Android 7 [20170708]: where is Glove Mode?
Thu Jul 20, 2017 9:36 am
I am sorry, glove mode setting had to be removed shortly because it caused serious problems with the touch-screen on some devices.
Gummidichtung
Sun Jul 23, 2017 5:11 am
Maybe, but for my device with latest update Touchscreen feels like Glove mode turned on all time.
I can use phone without touching the screen, 2-4 mm distance are enough to select things I do not want to..
Chipotte88
Sun Jul 23, 2017 8:24 am
Admin, you say that glove mode caused serious problem with the touch-screen. Do you have any solution to repair the touch-screen ?
Thanks a lot.
Priyanga
Sun Jul 23, 2017 8:27 am
My touch also same high sensitivity.
smarthousesys
Sun Jul 23, 2017 9:05 am
The BV6000S has the SAME problem!!!!
tomithyom
Sun Jul 23, 2017 8:06 pm
Looking at this simply, all the Blackview team would have to do is include a slider option like 'Pointer Speed' which adjusted the screen and button sensitivity when Glove Mode is on and off!
Parcheval
Wed Jul 26, 2017 12:51 am
That's the thing, you look at it "simply" as you just said.... With the same idea, to eradicate hunger in the world you simply have to provide food to everyone, easy, isn't it?
marko_aljinovic20
Wed Jul 26, 2017 10:06 am
I have a same problem... Please help...
Fri Aug 04, 2017 9:20 am
Sorry, it is not possible to let glove mode return in tater firmware versions. I will close this thread.
