kotsaris40
Problem with space of Blackview BV2000
Thu Jun 02, 2016 8:22 am
Hello, I have a big problem with downloading apps or taking fotos with the phone. As the internal free memory of the phone is ca. 1 GB and the free space of the microsd is more then 10GB I cannot update my apps, nor downloading new apps or taking fotos with the phone. Even if someone send me fotos the phone dont let them save. Every time there is a message that there is not enough space. WHY? The only thing I can do is to download songs. The phone is with the B1 firmware and has the latest updates. I minor second problem is, that even I have take the apps to the microsd, after updating them, the most of them are again on the phone and I have to move them again to the sd card. WHY? Please help, so I can work with the phone well. Thank you in advance.
Re: Problem with space of Blackview BV2000
Tue Jun 07, 2016 8:27 am
This is a common problem about setting.
what kind of downloading app u use, can set
sd card to be prior for storage.
Best regards,
Admin
