admin
Site Admin
Tutorial for the whole process of flashing ROM
Thu Sep 10, 2015 10:33 am
For some new users don't know how to flash ROM, This tutorial shows the whole process.
At first you need download the files to a new folder and remember the location then install
Download address: https://mega.nz/#F!S90AiTjD!sdVsi6JDiytWNRntFXr7qw
stagbeetle
Re: Tutorial for the whole process of flashing ROM
Fri Sep 25, 2015 12:14 pm
Hi, After a couple of hours I'm not having any luck with this. The camera is just not recognised - perhaps a Win 8.1 64 issue? On the camera I get 'USB connecting...' and on Win I get 'USB is not recognised' despite installing the driver in legacy mode without signature. I am using a black usb cable with 7 marks on the thin end (which I'm guessing matches the requirement for a "7P USB cable").
Is there a bin file I can load on the SD card instead?
Thanks,
admin
Site Admin
Mon Sep 28, 2015 1:57 am
did you mean the camera can not take photo or other?
then i can as our engineer to help you.
stagbeetle
Mon Sep 28, 2015 12:00 pm
No, I'm trying to update the firmware but I'd rather use a bin file on an SD card than troubleshoot a USB connection.
stagbeetle
Mon Sep 28, 2015 12:04 pm
(not sure if my previous reply was rejected)
I'm trying to update the firmware but the USB connection is not working.
Rather than struggle with the USB connection I'd prefer a firmware bin file that I can load onto the SD card.
Thanks,
admin
Site Admin
Tue Sep 29, 2015 3:23 am
The camera can use SD card to flash
stagbeetle
Tue Sep 29, 2015 6:41 am
OK but the ZIP file only has an ELF. Where can I download the BIN file to flash?
stagbeetle
Wed Sep 30, 2015 11:43 am
Hi, Any chance of getting a binary firmware update?
